32 ford crossmember advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2011, 02:10 PM
Last journal entry: Getting there....I think
i just bought a 32 ford cross front crossmember from speedway. getting ready to weld it on my 36 chevy truck frame. advice?thanks
Old 10-17-2011, 02:18 PM
Be sure to set the angle of the crossmember to reflect the angle you want for the axle. Caster is very important.
Go here
http://en.wikipedia.org/wiki/Caster_angle
On my 32's I like to run about 6 degrees caster.
Old 10-17-2011, 05:47 PM
Wiki Edits: 49
Randy is correct. You need to weld it in with the caster you'll need incorporated into its position. However, don't forget to also take the "rake" into account. If the car will have a 3*-5* rake you'll need to add that in as well.
As an example here's an illustration I did for my deuce to help me figure out how many degrees I would need. (The angles are a bit exaggerated just for illustration purposes.) This is not my car but it does have approximately the same rake I was planning.
The red line indicates the rake of the car while the green line shows "ground" level with 6* of caster. As you can see the rake adds to the amount of caster you need to set on your crossmember because it subtracts caster from the total. When I welded mine crossmember in I had 6* caster plus 3* more to account for the rake for a total of 9* on the crossmember. Total when the car is on the ground is 6* with this setup.
You also need to check your crossmember to see if it has a bit of caster built in... as mine did. Not sure if original crossmembers had that but some of the re-pops do for sure. If my memory serves mine had 4*-5* built in. Its not rocket science but this is just stuff you need to be aware of. I think you can see the built in caster in this pic.
Good luck.
Centerline
HotRodsAndHemis.com
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, WOW, What a ride!" - Anonymous
Old 10-18-2011, 06:41 AM
also... remember ride height should be engineered into that crossmember to where your lower control arms are roughly parallel with the ground. Some guys think that is only a suggestion.... then they wonder why the car handles like a skateboard with a missing truck bushing The other thing i would suggest looking at is if you purchased a crossmember with a coil spring top hat, I would send that back and exchange it for a coil-over eyelet upper mount.
Tony....
Old 10-18-2011, 07:25 AM
Tony....
I strongly believe he is planning on a straight axle ... no A arms
Old 10-20-2011, 10:38 AM
Thanks guys! Im new to the street rod stuff. I am assuming that the radiator should be mounted above this also correct?
Ford 2.3L advice ap72 Engine 10 06-25-2009 12:59 PM
55 Ford Crossmember Replacement Sweet-34 Suspension - Brakes - Steering 9 04-07-2009 12:07 PM
36 Ford crossmember removal... CamSweet General Rodding Tech 1 06-20-2006 12:19 AM
351M in a 54 Ford Pick up with A TCI Mustang crossmember baylow1 Introduce Yourself 1 08-03-2005 09:06 PM
Installing crossmember in 32 ford frame sodas38 Suspension - Brakes - Steering 2 10-07-2004 10:45 AM
