#1
32 ford frame, K-Member location?
This is my first post on Hotrodders.
I'm building my 3rd 32 ford frame and bought a SoCal K-member which is somewhat different than the ones I used from Speedway. I was wondering if anyone has the dimension to locate the brake peddle pivot arm that is installed on the SoCal K-member. Thanks TEH1955. Register now (free) or login to remove ads |
#2
I read your post last night and since I have a TCI chassis not SoCal I didn't answer. Obvious question but have you called SoCal to see if they have a schematic on their chassis or some other sort of plans?? If you have the body on the chassis you should be able to get a pretty good idea where it should go....not a lot of options on these old cars.
Fast forward a few......I just googled "SoCal 32 Ford K member" and it has their website showing the K member with what looks like the brake pedal pivot boss welded into the tube. (?????) |
#3
32 Ford Frame
I do appreciate your help. The other two frames I built were perimeter frames and I did not install the brake peddle pivot boss. I also fabricated the center cross member myself. The Socal K-member was pre-fabbed and thought it would save some time installing.
You are right the brake peddle boss is welded into the K-member, and that's the problem. I just want to locate it (front to back) in the correct place. I was going to call Socal tomorrow to ask the question. I just ran into the problem late Friday and it was too late to call. I thought I could get an answer over the weekend. Again, Thanks for your help. TEH1955 |
#4
![]() You should be able to figure it out ... because the pivot position depends on where your floor/toe board is Mine is a home built crossmember ... or I would measure it for you.
Sorry, I may have been a bit short with you... I don't suffer fools well. I'm workin' on it ... NOT ... |
| Thread Tools | Search this Thread |
| Similar Threads for: "32 ford frame, K-Member location?" | ||||
| Vin Location on 66 Chev P-U Frame | Bob Allen | Hotrodding Basics | 7 | 11-05-2011 08:03 AM |
| 1977 C10 frame cracks (stearing box location) | ekacpuc | Hotrodding Basics | 4 | 12-31-2010 06:30 AM |
| Electric Fan On/Off Control.....Location ...Location....Location | Viet Nam Vette | Engine | 17 | 03-20-2008 07:39 AM |
| Search for member location | Mousy | Site Suggestions and Help | 2 | 11-25-2003 10:24 AM |
| 1956 VIN frame location | mrferrisjr | General Rodding Tech | 0 | 05-18-2003 05:50 AM |
