32 ford frame width at front axle centerline - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2006, 04:38 PM
I'm building the frame for my '28 coupe. I'm using the front rails for a '32. By all the frame dimension reference I have, the frame is suppose to be 25 3/4" in width, at the centerline for the front axle. 26" for a stock '28, which would place the fenders in the right width at the radiator. However, when I set my rails to this width, and mock in the crossmember and '32 radiator shell, there is almost a 1 inch gap on either side, between the radiator shell, and the inside of the rails. It just looks too wide. Does this sound right? I don't have an assembled car around to check the measurements. What is the width of an installed '32 shell at the rear flange just above the rails?
On installing the front crossmember in a level and square jig, With a straight and level top rail, what would be a close suggestion on the caster angle for the front crossmember relative to the top rail? Going to run a split wishbone with a 4" drop axle. I know the angle is also relative to the ride height angle of the frame from front to back, just looking for something close for a start point.
Old 05-15-2006, 01:06 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That sounds pretty close...according to Wescott they build theirs 25 1/4 at the end of the front frame horns..the mounting holes for the radiator are 20" apart..
The castor angle of the front crossmember will be about the same as the castor angle of the axle so the spring acts in a verticle plane and does not bind..What is your proposed castor angle of your axle???
Sam
Old 05-15-2006, 06:30 AM
aiming for 5 to 7 degrees.
Old 05-15-2006, 07:30 AM
My radiator mounting holes are 20 inches.
If you are using a repro crossmember ... they are short and will not touch the inner wall part of the frame ...
I used a set of original 32 rails for mine ...
Old 05-15-2006, 08:40 AM
my cross member is from Brookville Roadster in Ohio. At the 26" outside width of a '28 frame, it just sets about 1/4 inch inside the frame rail on each side. Says it is suppose to be flush mounted to boxed rails. I think I'm going to extend it so it reaches the outside wall of the rails. It's mostly that the mock up just looks too wide with the grill shell.
I'm going to be running full fenders and a hood with sides, so I'm also going to have to modify the way the fenders and hood shelves mount up, to have it come together right.
Ford Econoline or Dodge A100 axle?? wheelsup64 Suspension - Brakes - Steering 4 02-13-2008 08:41 AM
Ford Econoline or Dodge A100 axle?? wheelsup64 Suspension - Brakes - Steering 2 01-26-2006 10:20 AM
axle width of ford 8.8 Can drive 55 Transmission - Rearend 2 06-06-2005 01:30 PM
How to old school a suicide front end on a 32' Ford teched Hotrodders' Lounge 2 09-22-2004 09:07 AM
Boxing 1932 Ford Frame sodas38 General Rodding Tech 4 09-17-2004 07:00 AM
