32 ford ls1 4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2004, 06:43 PM
32 ford ls1 4l60e
I was hoping someone could give me some info on putting an ls1 and a 4l60e into a 32 ford (gibbons body & frame)
First did you have to make a custom tranny crossmember & mounts or did you find someone that makes them? also what about eng. mounts?
Thanks for any info, first totaly built rod and am having a few shakes about getting this thing started, Paul
Old 01-27-2004, 06:50 PM
Gibbons is just down the road about a hour from my house. Do you already have the frame? If not.........Gibbons can build the frame for the engine and transmission of your choice.
IF you already have a 32 frame..........you will most likely have to modify the crossmembers you have..... the 4L60E is W I D E .......in the pan area.
I have a Turbo 400 in my Black roadster.......and the red coupe has a 200R4.........
DEUCE.........
Oh......by the way..welcome to the board.......
Old 01-29-2004, 08:39 PM
thanks
no i do not have the frame yet, i was going to call gibs. tomarrow, i didn't know that they built the frames custom like that, thanks for the information and the welcome!
Old 01-30-2004, 01:53 AM
gen3perf's Avatar
Re: 32 ford ls1 4l60e
I have built several motor & tranny packages for this, and can give you all the info you need. email me or call (760) 740-2505 PST if you want to talk.
