We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-28-2008, 03:13 PM
Walker Walker is offline
32 Ford rear in a Model A
I am installing a 32 Ford rear axle, with spring behind into a Model A roadster Frame, which had a spring over rear in it. How far back does the crossmember get kicked back to allow for the 32 spring? I am using the 32 rear with a HB quick change which is why I want to change to the 32 rear.
Thanks
Old 12-28-2008, 08:23 PM
Centerline's Avatar
Centerline Centerline is offline
HotRodsAndHemis.com
Centerline's barnstar
Wiki editor
Last wiki edit: Streetbeasts fraud controversy
Wiki Edits: 38
First determine where the axle centerline will be on the frame rails and then measure from the center of the axle to the center of the spring perch on your rear. Transfer that measurement to the frame and that is where the center of the crossmember will wind up in order to locate the axles properly.
Old 12-29-2008, 08:42 AM
I understand the concept of it, I just hate to have to reinvent the wheel every time do something. I'd hate to be off by 1/2" due to worn parts, or because i don't have the original axle, so determining axle C/L might be a little risky. I also figured this would have been done many times and there would be a method for modifying the crossmember that was tried and true. In fact I have seen a couple of schemes for adding two 45* pieces to the cross member, but no measurments.
Old 12-29-2008, 09:12 AM
Centerline's Avatar
HotRodsAndHemis.com
Wiki editor
Wiki Edits: 38
I'm not sure anyone here as actually done that particular swap before. I would suggest you ask that question to the guys on the HAMB. Those guys are into traditional hot rods and customs and I'm sure someone there will be able to answer your question with practical experience.
Be careful when you join over there. That board is MUCH different than this one and they can be a little hard on new people. They are NOT friendly at all to anyone who isn't into "traditional" hot rods. Or at least their definition of it.
Good luck.
Old 12-29-2008, 09:28 AM
Thanks, I'll give that a try.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "32 Ford rear in a Model A"
Ford 9" rear end wildfire78 Transmission - Rearend 4 10-20-2008 08:08 AM
32 Ford rear sus. John Singleton Transmission - Rearend 5 01-21-2007 09:30 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Parallel leaf rear suspension in a '32 Ford deuceguy32 Suspension - Brakes - Steering 2 09-29-2003 08:44 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
