'32 Ford Roadster, best glass body, best frame? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-18-2011, 03:36 PM
Wiki Edits: 49
Originally Posted by Fin
Weight would be an issue. The 4bt is 745 lbs wet, that is 70 lbs heavier than an iron head BBC and 170 lbs heavier than an iron head SBC (of course in reality I should be comparing it to an aluminum head engine). It would require more spring for sure.
The transmission would also be an issue. I would want a nongranny 5 speed. Since it would be a truck tranny it will be heavy. I would like to stay out of the after market tranny adapters ($$$) if I did go this route.
Not to worry. Its about the same weight as an early hemi.
Centerline
HotRodsAndHemis.com
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, WOW, What a ride!" - Jack Benny
  #32 (permalink)
Old 03-18-2011, 04:45 PM
302 Z28's Avatar
Just my opinion, but if you build that 32 with the 4BT in you will own it until you die, or you will wind up giving it away.
Vince
  #33 (permalink)
Old 03-18-2011, 04:53 PM
35terraplane's Avatar
32 Ford roadster
Vince
Vince, I'm with you on that, Plus how many die hard 32 guys would let you park with them, seems now they are all using flatheads, which is good with me.
Bob
  #34 (permalink)
Old 03-18-2011, 08:25 PM
Fin Fin is offline
Vince
Anything is better than a SBC!
  #35 (permalink)
Old 03-18-2011, 08:26 PM
Fin Fin is offline
Originally Posted by 35terraplane
...how many die hard 32 guys would let you park with them...
Bob, eagles don't flock! I'll be the rebel without a clue.
  #36 (permalink)
Old 03-18-2011, 10:18 PM
32 fORD ROADSTER
Oh But they do sit in groups, some times even big groups.
Bob
  #37 (permalink)
Old 03-18-2011, 11:21 PM
Fin Fin is offline
Bob
Well then, I'll hang out with the big gay truck guys running 5.9 Cummins and huge dual stacks in their pickup trucks.
I'll have to iron the bill on my baseball hat flat.
  #38 (permalink)
Old 03-19-2011, 01:57 PM
From experience, anywhere from a minimum $20 to upwards of $50K. The one I would tell you to avoid is already out of business.
Vince
Vince if you are talking about the one's that you got your body from I read some where they got the company back and moved it back to where they came from.
OLDROD
  #39 (permalink)
Old 09-25-2012, 01:49 PM
Speedline 32 (the old Down's Dearborn Deuce)
In January 2012 I made a deposit on a Speedline 32, the formar Downs Dearbord Deuce, to Ricky at Timeless Rods and Customs in Lula, GA. It has now been 8 months and all I have to show for it is vague promises. The Speedline 32 has great promise and is one of the few options if you want an up to date Dearborn Deuce. Time will tell.
  #40 (permalink)
Old 09-25-2012, 04:31 PM
dilligaf's Avatar
Best bang for the buck
You can probably rethink the hvac in a roadster and save some dollars. I am using a classic frame and I am very happy with it. They are out of So Calif. As for a body I went with a steel Rod Bod (since then they have sold out to an outfit in Denver Colo. but I think the same phone number forwards. Look them up in Sparks, Nevada.) The price of the Downs would probably more than cover the steel body. One thing to do is have the body lengthened 2". It makes all of the difference in the world. Love that you are going Ford in a Ford.
  #41 (permalink)
Old 01-31-2014, 01:37 PM
Has any one had any dealings with fastlane speed and rod shop in mission ks.
1937 Ford Roadster Body Hotrod_dino Hotrodding Basics 7 03-30-2015 01:37 PM
34 Ford door window installation in Glass body Samm Well General Rodding Tech 4 06-22-2010 10:02 PM
Bolting a glass body to frame? rubber spacers Adamrmr Hotrodding Basics 11 05-04-2008 03:00 AM
Body - Exterior, '32 Ford Roadster dadsdream 32 Body - Exterior 2 11-21-2006 10:40 AM
'29 Ford Roadster on 32 frame----Jomo Jomo Introduce Yourself 2 05-02-2006 10:59 AM
