Dilligf
The u joints should be lubed. They are new never lube joints installed by the drive shaft company when the new shaft was made.
I do not understand what being in phase means. How do I check that? |
Vibration on accelleration problems are tough.
Possibilities: driveshaft balance driveshaft phase U-joint lube the above all sound OK here, which would leave: out of balance / out of round tire bad motor mount there are others but they would not apply to a 32 highboy.... |
Take a Picture of the rear diff showing the angle of the pinion with the D/L installed and post it.
Out of phase.. Balance...out of round tire.... would be a speed related shake not a Decel or accel shake. New "neverlube" joint's are prelubed at the factory. |
Dilligaf
I have had the problem with two drive shafts. Both of them balanced. The yokes are on the same plane. The u-joints are new and prelubed. The engine is a crate racing engine from JEGS and is supposed to be balanced. The tires are new as are the rims and have been balanced. Shouldn't have a bearing on the vibration since it is only on acceleration. When just cruising along there is no vibration and none in neutral when I rev the engine or coast. I will check the motor mounts.
Thanks for all of the input. Great ideas. I know some one out there has had the same problem. I just have to find him (her). |
Centerline HotRodsAndHemis.com "The best car safety device is a rear-view mirror with a cop in it." - Dudley Moore |
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Tourqe Converter?
Most C4 torque converters, even performance versions, are no more then a remanufactured original part - and the last C4 was made for a full sized vehicle in '83 |
| 30 ford highboy rebuild. | davey nuts&bolts | Introduce Yourself | 1 | 03-22-2011 07:15 PM |
| ford 347 stroker stalls at biginning of acceleration | panmann | Engine | 2 | 08-06-2010 02:08 PM |
| Finishing 31 ford coupe highboy | coupe 31 | Introduce Yourself | 6 | 05-23-2008 11:15 AM |
| 32 Chevy highboy roadster | 32chevy vett | Hotrodders' Lounge | 3 | 12-16-2007 07:33 PM |
| new purchase, highboy roadster | pcoghlan | Hotrodders' Lounge | 14 | 02-28-2006 05:28 AM |
