Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 32 Ford roadster latch install
Old 04-16-2013, 01:11 PM
sedanbob's Avatar
sedanbob sedanbob is offline
You might consider adding a set of auxiliary terminals that you can access outside the trunk. Mine are attached to the spreader bar under the gas tank cover - on a '32, maybe the frame rail at the back of the rear fender.
