32 Ford roadster latch install - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2013, 11:05 AM
I have a 32 Ford roadster that the previous owner had installed a trunk latch but is missing when I bought it. The holes and slot are alread in as is the lid stricker pin. I would like to install another hinge in the same location so as not to have to alter the existing holes and slot. In addition I would have to add a release cable. Based on the attached pictures does anyone have an idea as to an existing latch that might work for me. Any help is appreciated.
ID:	73242   Click image for larger version
ID:	73243   Click image for larger version
Old 04-16-2013, 01:33 PM
Irelands child's Avatar
It appears to me that someone used a bear claw latch - and did a poor job of installing and reinforcing the surrounding ('glass?)material. I originally used a single rotor version on my '31 before installing the electric lid raiser and that looks very close. The only picture I can find of the bear claw set up is while I was welding in the mess.
Irelands child
Old 04-16-2013, 01:54 PM
32 latch
I agree that someone botched the first try. Maybe that's why it's missing. I thought that when I finally find a latch that will fit the openings I would add another small plate behind it to stiffin it up and add more support. I appreciate the suggestion on the Bear Claw latch. I'll contact them prior to buying so I can get some measurements before I purchase.... I had installed an actuator on the lid of my model A but it was so slow in opening I didn't like it. In addition, having no latch, I was unable to open the trunk lid on a dead batt. Sometimes I forget that you just can't put a batt. in a trunk with a trunk that opens on electricity... duh.... Thanks for your comeback.
Old 04-16-2013, 02:11 PM
sedanbob's Avatar
You might consider adding a set of auxiliary terminals that you can access outside the trunk. Mine are attached to the spreader bar under the gas tank cover - on a '32, maybe the frame rail at the back of the rear fender.
Old 04-16-2013, 03:31 PM
I made up a pretty healthy bracket for mine - that assembly is still around if I can find it in the current disaster in my basement shop (I'm in the middle of a honey do home improvement project) and photograph. No promises though
My little Odyssey 680 battery is under the stereo :
Name:	Batt box & stereo1.JPG
Irelands child
Old 04-16-2013, 07:14 PM
A couple photos of what I'm no longer using - but worked great before I decided to go with the electric trunk lift:
ID:	73262   Click image for larger version
Irelands child
Trique Manufacturing bear claw latch install triquemfg Body - Exterior 10 12-07-2009 04:59 PM
37 ford door latch 52plymouth Body - Exterior 14 11-06-2009 08:18 AM
Bear Claw Latch Install hotrodjim58 Body - Exterior 8 03-06-2008 06:07 PM
door latch parts for a 56 ford pu wiseguy50 Body - Exterior 4 01-12-2005 09:38 PM
Deuce roadster windshield install HB32 Body - Exterior 0 08-10-2002 06:10 PM
