32 Ford Steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2014, 01:29 PM
32 Ford Steering
Putting together 32 with 56 ford steering sector, using hair pin radius rods. Having clearance problems with pitman arm. Does any one know what other type pitman arm will work to clear radius rods. I do not want to turn the pitman arm straight up, needs to be in the down position. Thanks Jack
Old 02-03-2014, 06:54 PM
Are your radius rods mounted to the side of the frame or with a tab hanging below the frame. This will make a difference.Check out the pic of my 32 on my profile. These are mounted on the side of the frame.
Old 02-04-2014, 07:07 AM
onefalcon
Forgot to put on last post, the radius rods are mounted to the side of the frame.
55 Ford steering fairlaneguy Suspension - Brakes - Steering 1 09-07-2011 02:14 PM
36 Ford Power Steering 454 Rattler Hotrodding Basics 8 05-11-2011 01:53 PM
32 ford steering columns mikej6 General Rodding Tech 6 10-21-2010 01:27 PM
Best steering for 32 Ford p/u 09bigboy32 Suspension - Brakes - Steering 3 09-10-2009 04:37 PM
34 ford steering coloum blklar Hotrodders' Lounge 4 10-27-2006 08:16 PM
