32 ford steering columns - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2009, 07:43 AM
I am building a 32 ford high boy roadster.
does anyone know what size (length),tilt or no tilt ,with shift,gm column would work? need to buy used,low buck.
what make,model,yr steering column would work?
I would like to have column shift outside of firewall.and nice to have key on column.
an running flathead with a 350 turbo.
any help would be appreciative
MIKEJ6
Old 12-10-2009, 12:29 PM
Guest
Depends on your steering box, planning to use a vega stlye? You'll find about 35" to be about right (incl the wheel), it'll end just past the floor so you'll have enough room for the double d shaft and 2 universal joints. The vega box'll be just about under #1 cyl. Not enough room for power steering with this setup but with sbc may not be an issue. I am thinking about doing away with the vega box and using one of those unisteer semi-rack, thye claim next best thing to power steering. Hope this helped, oj
Old 10-21-2010, 12:21 PM
Steering to fit a 1930 Model A
Where can i find a complete Steeering Column to fit a 1930 Model A, an after market column
Old 10-21-2010, 12:28 PM
Steering Column
I just put my 1930 Model A body on a Heiths Frame, and am looking for a drop in Steering Column, it has Rack and Pinion Steering, 9/16s Shaft, 26 spline, where can i pick one up?
Old 10-21-2010, 12:50 PM
302 Z28's Avatar
Ididit 32".
Vince
Old 10-21-2010, 12:52 PM
35terraplane's Avatar
32 ford column
I really think you should start your own thread, and not ride the tail of Mikej6, if more people get on this thread and don't see what he started with, you will get the help and he won;t. With your own thread and his you will each get help I'm sure.
35terraplane
Old 10-21-2010, 01:27 PM
Steering Column
Thanx Vince
'32 Ford F/G Closed Cab P/U Steering Change Over? wathizname Suspension - Brakes - Steering 31 03-27-2011 12:28 PM
50 Ford Tudor Pwr Steering Conersion Schenkeinstein Suspension - Brakes - Steering 5 01-29-2010 04:58 PM
Power Steering Ford Taurus ArmyofOne Engine 2 12-14-2007 08:31 PM
steering column for 40 ford howie1940-50 Suspension - Brakes - Steering 3 08-17-2007 04:18 PM
Small block Ford steering conflict rhphotrod Engine 5 07-27-2007 03:32 PM
