'32 grill into a t-bucket - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2005, 06:34 PM
dorksrock's Avatar
that one hot rodding kid
i have seen a few t-buckets with chopped 32 grills, but would it look too hunkie dorrie to use a full 32 grill? the only reason im asking is because im planning on using a flathead and the only radiator i can find close is the '32.
thanx,
Jordan
Old 06-13-2005, 07:18 PM
poncho62's Avatar
Wiki Edits: 5
Too tall............................like In said in the other thread...............CUSTOM RAD.
Old 06-14-2005, 10:28 AM
Frisco's Avatar
Glad To Be Here
thanx,
Jordan
I have built two "T" buckets in years past. Using a stock height '32 shell & grille would work if the "T" body was mounted on top of the frame and the '32 shell were mounted lower than normal. Traditionally; "T" buckets are being built channeled over a frame. To achieve the correct (to the eye) side view; the top of the radiator shell should be level or just below level with the lowest point of the cowl looking from the side. To get this look, most builders will use a custom radiator and a sectioned shell. Both of these units are then mounted lower than normal between the frame rails.
32-34 ford grill shell mehegan Body - Exterior 1 01-05-2005 07:13 AM
aluminum grill repair helrazr3 Body - Exterior 4 10-17-2004 04:03 PM
My bro's gas grill Beenaway2long Hotrodders' Lounge 5 08-02-2004 01:20 PM
32 grill in a 30 ford deathbypontiac Body - Exterior 2 07-30-2004 08:34 AM
31 grill to 32 rodd1 Body - Exterior 0 12-16-2002 09:22 AM
