32 hi boy ride
Hi everone I am the deucedr I have 32hiboy I have not driven for two years my question is any ideas for a smoother ride it has been sitting since back injury all of 600 miles would air bags work on rear onl
y? also a bike rack for early stingray bike. thx |
Airbags........
Hi,i think the airbags would soften the ride for you,if you dont use a lot of air pressure,are you planning to use the bags in conjunction with springs?if so,i would use very weak springs.
without knowing about your current set up, we could only guess as to what you could do to soften your ride..
Thank you all for your help
The TRADITIONAL way to improve the ride is to reduce unsprung weight. Lighter tires, lighter rims are a start. I have a aluminum center section in both my 32's. It saves almost 22 pounds ... right off the rear end. I have a aluminum driveshaft. You only save half the weight but it helps.
Spring rate and the angle of your shocks also play a important role in the ride. ![]() I have a fabricated rear suspension under my 32's. The car rides on coil springs ... and rides very nice. ![]() I was very weight conscious when I was building the cars. I also have aluminum heads, intake, a 9 pound starter. ![]() DEUCE ... Moderator
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
I I love you I may be back in my car because I know it the brotherhood of the street rodders is great I cannot believe this website I want I want to say thank you very much all of you for the great answers
| Oh boy can I use some help..... | 1Bad406sbc | Engine | 5 | 09-21-2009 11:03 AM |
| Air Ride, but not for your normal ride... | MiniMiniTrucker | Suspension - Brakes - Steering | 35 | 03-30-2009 02:30 AM |
| New Boy | Troy Tanner | Introduce Yourself | 2 | 11-02-2007 04:18 PM |
| Howdy - 32 Ford Po-boy Low-boy | kabankers | Introduce Yourself | 3 | 06-14-2006 07:16 PM |
| Oh boy!!! | mustangbaby | Hotrodders' Lounge | 7 | 03-09-2003 11:07 AM |
