Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 32 Roadster/S-10 Blazer frame
Old 03-07-2012, 12:15 PM
Deuce Deuce is offline
Originally Posted by brentdalley
I know the wheelbase is close but what about the rest of the dimensions? Can I mount a 32 Ford full fender roadster on an S-10 frame?
NO ...
As the owner of two origina steel bodied 1932 Fords ... there is NO WAY to make a S-10 frame work with a full fendered 32 Ford.
Look at this photo of a S-10 frame and compare it to a 32 Frame. WAY different.
You can buy a " correct " set of repro frame rails and build yourself a decent 32 chassis for a lot less trouble ( with better results ) for a lot less time and money.
Here is a photo of my frame rails ... in the jig ...
You might look at my phptp jpournal on the build of my 32 Ford 3W coupe.
Go here
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
DEUCE ... Moderator
