Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 32 roadster shimmy and shakin
Old 10-21-2009, 09:59 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
You need to check and see what degrees your king pins are set at.. did you make sure you didn't lose a weight off one of the wheels ??? May need to get them rebalanced..
A friend had one do that, And he reset the degree on the king pins. And put some better tires on front, and fixed the problem..
