Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 32 roadster shimmy and shakin
Old 10-21-2009, 10:14 PM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Centerline is right..When I build a frame, I build it level, But I set it at 7* so when it's on the ground at ride height. with the rake of the car you will end up around 3* to 5* degrees.. You want it between 3* and 7* degrees..
