#1
32 top mount
Does anyone have the mesurement as where to put the lower mounting tab on 32 roadster body? this is the tab that the top mount to.
I need the measurement from door opening to center of the hole. then the distance from hole down to the body. also the size of the tab,HxWx thickness and the hole size and is it tapped? MIKE Register now (free) or login to remove ads |
#2
32
Find Deuce and PM him. He should be able to help, he knows as much as anyone on the 32. Bob |
#4
Deuce
Go to search, Write Deuce, Go down to thread, 32 suspension, open that, go down about half a page, and you will find Deuce, click on the line under Deuce and it will ask you if you would like to PM him, click on that and leave your message he will get back to you. Bob |
#5
The center of the hole is back 4 and 1/2 inches from the body edge. The hole is 1 and 1/4 inches high and NO ... the hole is not tapped nor round. It is square. It is 3/16ths thick. These measurements were taken off my Henry Ford original steel 32 roadster and the Brookville roadster I have in my shop. I am working on it for a friend. ![]() ![]() You can go here to see the bracket and it's placement. http://www.wescottsauto.com/Body/bo...-1932Bodies.pdf The bracket is available from Wescott or Brookville. You can go here to see how the setup works http://www.topsters.com/ Deuce ... Moderator
Sorry, I may have been a bit short with you... I don't suffer fools well. I'm workin' on it ... NOT ... |
#6
top mounts
THANKS.
It is really nice to have a place to get inf. from knowledge people. why is the hole square? and not round. I like your cars. How do you keep the gararge so clean??? thanks again MIKE |
#7
![]() Here is another photo ... ORINIGAL 32 Ford roadster ... Not my roadster but it is a old magazine cover roadster from the 60's. I have no idea why the hole is not round. I would imagine the hole is broached ... and was possibly square to hold the bracket in place while being machined. I guantantee you ... HENRY had it square for a reason. .
#8
32
Deuce I hope you don't mind that I sent mike looking for you, as I was sure you could answer his question. Bob |
#9
Not a problem at all ... We all have our own little area of knowledge and mine just happens to be 1932 Fords
| Thread Tools | Search this Thread |
| Similar Threads for: "32 top mount" | ||||
| 283 front mount convert to side mount | jomil | Engine | 10 | 01-19-2007 09:09 AM |
| How much clearance should there be between motor mount and motor mount bolt? | firstgear | Engine | 3 | 06-09-2006 08:31 AM |
| To Re-mount or Not to Re-mount? | fiftysix Chevy | Engine | 1 | 01-27-2006 06:23 PM |
| Mount | TWOPLYM | Transmission - Rearend | 1 | 07-08-2005 04:38 AM |
| In Car LCD Mount | wasabi | Interior | 7 | 12-27-2003 09:31 PM |
