Is 320 to 600 too big a jump in grit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2010, 02:57 PM
Hi guys!
Finally got my car in the 3rd round of block sanding, did 120 dry twice and moved up to 320 currently.
I was just cruising around online and saw that a lot if not most people recomend 400 grit then 600 before finishing with solid color SS Urethane.
To me 320 and 400 seems like a pretty insignificant change in grit but I'm far from a professional painter. So the question is can I jump from 320 dry to 600 wet and finish with a SS Urethane and be ok?
Old 07-05-2010, 03:06 PM
Rix-Trix's Avatar
Last journal entry: Box is back on the truck
Yes you can go from 320 to 600, myself I would have went to 400 when you went to 320 but now that you are there I would continue with 600.
Old 07-05-2010, 08:32 PM
BMM BMM is offline
You sanded with 120 than moved up to 320 without priming in between? Right there is too much of a jump for my liking. The coarsest I go if Im not priming after is 220, rarely.
Anywho, I've been told that anything more than 100 grit difference is less than guaranteed to remove the scratches.
Old 07-05-2010, 09:25 PM
Rix-Trix's Avatar
Yes I agree BMM, but that has to be a typing error, I'm hoping that he ment 220?
Old 07-06-2010, 07:57 AM
Yea typing error, I blocked with 120, re-primed, blocked with 120/320 combo, re-primed (3rd time) and now i'm sitting on a fresh coat of primer with guide coat. The plan (currently) is to use the 320 to knock down some of the orange peel then jump to 600 for final prep.
Grit - how fine is too fine for adhesion? cboy Body - Exterior 41 06-28-2009 05:20 PM
Big jump when i shift "d" (1975 Camaro) Calderone Transmission - Rearend 2 03-28-2008 05:30 PM
Graduated to 320 then 500 grit, tips on blocking, same as coarser grits? Ripped Body - Exterior 4 01-08-2008 11:10 AM
Solvent popped, so I wet sanded - 320 grit ok? BIGSKY Body - Exterior 14 07-03-2007 11:17 AM
Is 600 cfm big enough? 1973ChevroletNova Engine 4 02-24-2003 02:00 PM
