The 327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2007, 07:26 PM
J.D J.D is offline
The 327
I am going to build a 327 for a 1968 camaro Rs. It will be a street car but I want it to have some balls! What do you guys suggest? I like the idea of a screamer, Should I stroke it? I have built some 350's but I am told a 327 is a little diffrent. Like I know That the crank is small journoul and the stoke is diffrent and I know that the wrist pin on the piston is set diffrent.What all can I use from my 350 performance stuff? Please help!
Old 08-02-2007, 08:53 PM
327NUT's Avatar
Is the 327 the original '68 ...if so then its a large journal and its basically the same block as a 350. Just get a 350 crank and pistons and whatever else you decide you need and you're set.
Old 08-03-2007, 12:21 AM
Gotta watch out for those '68 327's. Some early '68 cars got the '67-spec engines leftover from the '67 model year, so check to make sure.
Old 08-03-2007, 10:01 AM
J.D J.D is offline
the 327
Well this 327 is out of a 1967 camaro that we had first, We were ran off the road by a drunk driver and plowed it into a tree. We found this 1968 camaro garage kept with a 6 cyl. So the motors were swaped. this car has a 2 speed powerglide tranny and I have no idea of the gear, We once thought we would push the outer limits of this car and ran 120 in first@ about 7700 rpm! It didn't hurt the motor (I don't think) but we did throw all the belts off!
327 '89 Trans Am GTA suggestions 3rdGenFreak Engine 2 06-29-2007 08:45 PM
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 09:22 PM
help make my 327 angry!!! 70chevelle327 Engine 40 04-24-2007 06:33 PM
327 TO 350 CONVERSION 34FordPickUp Engine 4 08-27-2002 06:56 PM
327 rebuild help. SUGGESTIONS PLEASE DeezImpala Engine 1 06-24-2002 10:06 PM
