Thread Tools Search this Thread share on Facebook
  #1
Old 02-21-2009, 03:33 PM
ericnova ericnova is offline
i have a 1968 327 and it dose not have a bolt hole for the harmonic balancer so how do u put it on and keep it from fallen off the crankshaft it was formed that way so im lost never seen one like it.
Register now (free) or login to remove ads
Old 02-21-2009, 03:57 PM
DoubleVision's Avatar
DoubleVision DoubleVision is online now
Socially Unsociable
For a 68 that is indeed rare. The early small blocks didn`t use a bolt, they relied solidly on press fits until they got wind of drag racers winding them up to 8000 rpm and the balancer flying off. By 68 as far as I know they were all drilled and tapped so yours maybe a earlier model. Anyways, you would have to have a machine shop do this for you as it would have to be perfectly straight drilled and tapped as well as the correct depth.
Old 02-21-2009, 04:57 PM
bracketracer bracketracer is offline
You wont have to have a machine shop do it. I had a 327 in my 55 chevy and changed the cam with the motor in the car. I got the balancer off and relized wow no bolt hole . I drilled it with a drill as straight as i could and tapped it out with threads and it worked great. So if you take the time and pay close attention its very easy.
Old 02-21-2009, 05:20 PM
oldbogie oldbogie is offline
The early engines used a press fit balancer, they work loose with time. Moroso sells the proper bolt 7/16s X 20 threads 2-1/4 inches long. There should already be a hole in the crank, tapping if with a proper sized tap will get you there.
http://www.moroso.com/catalog/categ...p?catcode=23026
Bogie
Old 02-21-2009, 10:32 PM
junior stocker's Avatar
junior stocker junior stocker is offline
SBC balancer bolt.
I too had a small journal 327, 340 HP short block, aftermarket solid lifter cam and kit, fully ported/polished 461X heads, 300-25 Holley intake with a 750 DP, 4 into 1 upswept headers; all in a real short wheelbase FED. NO BALANCER BOLT, and the tech people questioned me on it; let me run the digger, but told me to "bolt it". This was late 70's/early 80's. So, I had a fixture that was actually part of a hub puller, installed the thing on the dampener, got a reverse rotation drill bit, and a reversable drill. Started the engine, stuck the drill bit in the fixture, turned on the drill, and drilled away with the engine turning one way while the drill bit went the other; worked pretty good. Enlarged the hole after, and tapped it, put a locktighted bolt in it. Was just fine. Now, the same engine would need an SFI balancer. It's the same engine for my 56' Sedan Delivery with an intake and camshaft change. Went 9.23 @ 146 in the digger. If the crank's out of the engine, then have it done by a machine shop, other wise, you can be creative if you have the room to do so. This is the first time I've ever mentioned this, even after all the prior threads with the same problem.
Old 02-21-2009, 10:57 PM
HPfreak HPfreak is offline
I remember a long time ago after putting together a very high rpm, hp, 350 that the last thing I was doing on the stand was going to put on the balancer. NO bolt hole at all, I was like wth. Anyway, I got the Moroso bolt, found out the right drill and tap size and drilled it with a hand drill, I used a cobalt bit and it went right in. Taped it and everything was fine. Just keep the drill as straight as possible.
Old 02-22-2009, 07:07 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
You'll find the balancer goes back on a lot easier if before you install it, you heat it up by boiling it in a big pot of water on the kitchen stove for about 30-40 minutes. When you are all ready to install, use the lil womans kitchen oven mitts to pick up and handle the 200°F+ balancer and toss it on.
Heating up the balancer in water expands the precision press fit hole just enough so it goes on easy.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "327"
ThreadThread StarterForumRepliesLast Post
327 large and small journal motors31 Ford CoupeEngine909-08-2008 12:09 PM
327 '89 Trans Am GTA suggestions3rdGenFreakEngine206-29-2007 07:45 PM
Chevrolet 327TEEMCDEE9552Engine1506-09-2007 08:22 PM
help make my 327 angry!!!70chevelle327Engine4104-24-2007 05:33 PM
327 build up using 1964 and earlier parts ONLYchopperimpalaEngine2310-06-2005 01:07 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
