Originally Posted by cobalt327
With the valve adjustment on the lifter that you can push down, you want to set the preload with the lifter all the way at the top of its travel.
Thanks for the reply. I need to study everything you said before I answer you back. However, I am working the problem related to the last thing you said.
Do you mean,,,After the valve is adjusted, I should or should not be able to push the rocker down this extra .140 travel? Its pretty easy to push down.
Do I need to remove all clearances (this .140) and then adjust the valve? Thanks.
