Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327
Thread: 327
  #33 (permalink)
Old 02-06-2013, 01:47 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by 1971chev View Post
So with a cam swap and long tubes what kind of hp could I see.
Assuming no other power killing issues at least another 15%.
This is the minimum I would expect. and the power and torque will come sooner.
The truck will feel a lot more torquey and powerfull. You won't need the dyno to tell you that.
First test ride is going to be a eye opener.
Make sure you have correct valve springs
the fuel system has to keep up @ WOT.
carb is a bit too small.
more boost.
You have barely scratched the power potential.
further: the dyno only tells you how much power is created.
it does not tell you if you are making good use of it. (acceleration)
