Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327
Thread: 327
  #39 (permalink)
Old 02-07-2013, 11:15 AM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by 1971chev View Post
I just dynoed my 327 and came out with 300 rwhp and 360 ftlbs with 6 pounds of boost through a weiand 177. The motor is bored 30 over 9-1 compression ported double hump 64 cc heads, comp 292 h cam and ram horm manifolds. My question is why does the 300 seem low for this motor.
Didnt read the entire post so maybe i missed something but 300 does seem low for a 327 with a blower. I think 327 with that cam and good heads should make 300 without the blower.
What type of dyno did you use. Was it a mustang dyno otherwise known as the heart breaker. They read much lower than most dynojet dynos.
Was the engine tuned for the blower to safe or performance levels. sounds like its got the safe tune running and needs some tuning to make some power.
Also do you have a lean rich guage hooked up. This is very important on a blown engine. Helps keep the tune in safe level and can alert you if the fuel pressure drop suddenly.
