tell me what matters more. A dyno number you can brag about and/or get a warm fuzzy feeling about,.... or a fast truck?
This blown 327 has the potential to make in excess of 480hp (engine dyno) way over 500hp+++++++++ on race gas and high boost. and push your truck to mid 11 second ET's with traction. Thats a fast pick up truck. Remember a dyno is just a testing device to see power gains and losses from the changes you make. if you are after a big number, for the sake of a number ,, from a chassis dyno you are going to be humbled. The dyno number created will improve every time you improve the combo. If I/or anyone else could tell you exactly what x+Y='s we would not need test dynos at all. You could just pay me the dyno test $$$'s and I'd ask my magic squirrel and he'd tell us all. And I'd give my magic squirrel a peanut. and we would not need any more dynos or real dyno testing. What power number would you like me to tell you? How much money do you got? How much work are you wiling to do to actually find make the improvements to the engine so it can make more power? The dyno will tell you when you have made a gain or made a loss. That is its purpose. Controling the test conditions and eliminating common power robbing faults ( fuel/spark/ mechanical etc) matter. You have made a good start but you have a bit of a testing and learning curve and you will not solve all the issues in 1 day. This is R O C K Y My Magic Squirrel. Way more flattering than any Dyno.... Last edited by F-BIRD'88; 02-06-2013 at 02:14 PM. |
| The Following User Says Thank You to F-BIRD'88 For This Useful Post: | ||
spinn (02-07-2013) | ||
Im thinking a fast truck would be alot better than a dyno number, would still be nice to break 400 at the wheels I dont see why that would be a problem, I did it with a 4.6 mustang on 6 psi of boost
DYNOS are tools!
See if the RPM levels match what you want for a finished product? If your torque figure is in the wrong proportion to your horse power figure find out why,,,,camshaft has already been addressed,,,, decide if 1 3/4 tube primary headers are in fact better than 1 5/8 headers for your application? dont rant about the top power figures until the proper tuning is finished |
Well I have shown you the areas where there are major obvious supercharged power restricting issues.
And further dyno testing will verify gains you make by improving it. The drag strip will tell you if its fast and show you when you have made it faster. ny adding engine power, improving traction and using the engine power more efficiently. They are both usefull tools. The 177 blower is well capable of making well over 650 real engine horsepower. A chassis dyno typically shows a number that is between 15% to 30% less than the engine brake dyno test numbers. and there are many many variables. Higher 1/4 mile MPH from the track means more engine power. the math is 234 x the cubic root of (weight to power) ='s road horsepower weight is with driver. Last edited by F-BIRD'88; 02-06-2013 at 02:31 PM. |
Do the mods everyone agrees on,bigger carb,better exhaust,different cam timing.Do some serious math.And listen to fbirds magic tree rat,you should make very big improvements. Dyno would be nice to set the fuel curve safely
Didnt read the entire post so maybe i missed something but 300 does seem low for a 327 with a blower. I think 327 with that cam and good heads should make 300 without the blower. What type of dyno did you use. Was it a mustang dyno otherwise known as the heart breaker. They read much lower than most dynojet dynos. Was the engine tuned for the blower to safe or performance levels. sounds like its got the safe tune running and needs some tuning to make some power. Also do you have a lean rich guage hooked up. This is very important on a blown engine. Helps keep the tune in safe level and can alert you if the fuel pressure drop suddenly. |
Youre crazy man. I can dig. |
How well will the summitt cam k1105 has anyone ever used this one
The Crane cam is a little sweeter overall. I have used both. Do you have valve springs that are up to the task? |
| 68 327 I.D. | trubblemakr | Engine | 7 | 12-29-2011 06:20 PM |
| 68-69 327 | sscardino | General Rodding Tech | 21 | 03-16-2011 08:52 PM |
| 327 need advice, opinions from guys who know their 327's | jafroyd | Engine | 9 | 07-21-2009 06:19 AM |
| 327 | White21 | Engine | 6 | 08-10-2008 08:33 PM |
| 327 for s-10 | russ 61 | Engine | 1 | 11-28-2003 10:11 PM |
