327 235hp heads - accessory holes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2011, 07:57 AM
Hey guys,
So I have this 69 chevy 327 in my garage and it's complete from oil pan to carb (but no valve covers or timing cover). I was looking at the heads... they're small port 185 heads for a 235hp motor... but anyway it seems that both heads have 3 accessory holes in one end and one hole in the other end. When I put them on the engine, that means that one head has 3 holes facing the front and the other only has the one hole..
Aren't both heads supposed to have 3 accessory holes up front? Or does it not matter?
Thanks!
Old 10-15-2011, 08:01 AM
poncho62's Avatar
Wiki Edits: 5
Depends if you need to bolt anything to them....AC, PS, alternator.....I would imagine that whatever was needed in 69 is there
Old 10-15-2011, 08:14 AM
DoubleVision's Avatar
3 holes on one side and 1 on the other is how it worked all the way up til they converted to serpentine systems. The alternator bolts on to the passengers side on the V belt system, it only had 1 bolt in the head. The upper of the alternator was bolted to a bracket that mounted to the water pump and the intake manifold.
The other side the A/C bracket mounted to, and it used 3 bolts in the head.
No matter what heads you find, there is no 3 bolt head that will bolt on to the passengers side and there`s no 1 bolt head that will bolt on the drivers side as all heads came with 3 bolt holes on one end, 1 on the other, and if you take the drivers side head off and put it on the passengers side now the 3 bolt holes are in the rear and the 1 bolt hole is in the front.
Old 10-17-2011, 05:51 PM
great thanks for the info!!
So the driver side should have 3 holes and the passenger side should only have 1... got it!
new heads have no accessory holes... now what?? 350cruiser Hotrodding Basics 5 09-10-2011 08:26 AM
no accessory holes! zoomo Engine 3 08-26-2010 10:40 PM
Accessory Holes youngc0@mchsi.com Engine 5 07-04-2006 11:03 PM
head accessory holes hot57 Engine 12 07-08-2003 06:29 PM
can i drill accessory holes striker86 Engine 4 05-25-2003 01:24 PM
