Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 275hp rebuild
Old 04-05-2012, 03:29 PM
ap72 ap72 is offline
Banned
Originally Posted by cobalt327
An LT1 that needs nothing mechanically for $400? Maybe. Maybe you get it home and take it down for fresh gaskets, etc. and find the short block needs the works, and one of the heads is cracked.
The idea of stuffing the 27 block w/a longer arm and pistons to match the CR and the stroke is a sound approach IMHO.
In that car, reusing the fuelies would look right, Vortecs will run better, your choice.
Using styling cues from that era on the engine (finned aluminum v-covers, a front-mounted oil fill tube, things like that) will offset any loss of "the look" from using different heads to some extent- but fuelies will be the best for popping the hood at the Steak & Shake.
If the intake has the U-shaped heat riser channel, be sure you use the right type of stainless steel clad gasket between the intake and carb.
Nice looking car, BTW. Good luck.
$400 is more than the local salvage yards charge, including warrenty. As far as looks, a little orange paint goes a long way for 99% of the people out there. And finned valve covers and such will really be what draws the eye, not the casting symbol on the front of the heads.
