Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 or 350
Thread: 327 or 350
Old 10-02-2011, 08:04 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
There should be a suffix code stamped just in front of the passenger side cylinder head. Look that up and it'll tell you what you have. Or you can pull the oil pan off and check the casting number on the crank. Chances are very high that it's a 350 though. The 3970010 casting number was used throughout the 70s.
