327 or 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2011, 07:04 PM
colton755's Avatar
327 or 350
i have a sbc with the casting #s 3970010 with a 4 bolt main is there any way to tell if its 327 or 350
Old 10-02-2011, 07:38 PM
poncho62's Avatar
Wiki Edits: 5
Measure the stroke.......
Its a 350.....there were no 327s with 4 bolt mains........Of course, this fact has been disputed many times
Ontario Rodders
Old 10-02-2011, 08:04 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
There should be a suffix code stamped just in front of the passenger side cylinder head. Look that up and it'll tell you what you have. Or you can pull the oil pan off and check the casting number on the crank. Chances are very high that it's a 350 though. The 3970010 casting number was used throughout the 70s.
Old 12-13-2012, 05:36 PM
actually in 1964 there was infact a 4 bolt main 327 suffix code T0221hv it was made specifically for the corvette 350 hp manual trans duel point ignition built in totawan ny
Old 12-13-2012, 06:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A 4-bolt 327 SMALL JOURNAL. Now, THAT'S a new one!!!
Old 12-13-2012, 08:08 PM
L79 super h output 327 was a rally motor with 7 quart oil pan 4 bolt main look it up engine suffix is t0221hv
Old 12-13-2012, 08:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't need to look anything up to know there was no 4-bolt SJ production SBC engine. 327 or otherwise.
