-   -   327 or 350 ? (http://www.hotrodders.com/forum/327-350-a-222358.html)
camaro1982 07-30-2012 06:52 PM
327 or 350 ?
Hi all i got engine and cant found what kind is it dont know if you can hlp ?
casting# 3970010
engine code # MM01800
Its all i have hope some one can hlp me i wanna know how much hp i got :/
camaro1982 07-30-2012 06:54 PM
i have remove hoil pan and i know its 4bolt main
mike Crawford 07-30-2012 06:58 PM
350 four bolt main .. Anywhere from 1970 to 86.
Very popular 350 casting ..
No 327 engines carry that casting number and they never built a 4 bolt main 327
camaro1982 07-30-2012 07:03 PM
Oh ok thx now need found how many hp got in that do i need suffix for find how much hp ?
mike Crawford 07-30-2012 07:09 PM
1970 block .. about 250 horse
1986 about 160 horse.
3970010 block with four bolt main most likely came from 3/4 ton or one ton truck or van
350chevyrob 07-30-2012 07:12 PM
The only way to really find out if it is a 327 or 350 is get the suffix code off the block located above the water pump hole on the passager side of the block
350chevyrob 07-30-2012 07:17 PM
350chevyrob 07-30-2012 07:25 PM
And a 327 dose have that casting number so dose the 350. If you look in the back of the engine behind the fly wheel and there is casting numbers with a 010 and 020 its most likely a hi nickel block
camaro1982 07-30-2012 07:29 PM
there is no suffix on its all gone :( only thing there is the engine code MM01800 this can hlp ?
http://www.hotrodders.com/forum/imag...c/progress.gif
350chevyrob 07-30-2012 07:36 PM
Here check out this link on engine codes
Small Block Chevy Engine Block casting and code identification
camaro1982 07-30-2012 07:39 PM
i have already go to that site but im frensh and i cant find how much hp i got in there i dont wanna put to much money on it if it only got 180hp :( i have already 650 holley 2pump edelbrock dome and came stage 3
camaro1982 07-30-2012 07:40 PM
cant found nothing cuz of those dam MM and i try so many site my number match with nothing
350chevyrob 07-30-2012 07:46 PM
That is a stock up rating ..that block can handle at lest 400 hp it all depends on who much money you have to spend...hot rods don't run on gas they run on money and lots of it lol
camaro1982 07-30-2012 07:50 PM
with all of my set up do you think im close to 350-400 hp ?
350chevyrob 07-30-2012 07:56 PM
I don't know what you have plus it takes good heads ,cam,prisons, compression,and a boat load of stuff it get 400+ HP.
