327 or 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2003, 11:24 AM
S10 Super Sleepers
Post 327 or 350?
I have a 350 block 4 bolt main and a 327 block 2 bolt main. I can't decide which one to use in my sonoma. I'm thinking of the 327 because of its high rpm range, but the 350 has more hp. Any help?? The engine will be built the same regardless.
Edilbrock pro-flo injection (teflon coated)
Roller: cam, lifters, puchrods, rockers
headers
centrifical supercharger
9.5 to 1 compression
I would apreciate any input
Thanks
scott s
Old 04-23-2003, 01:18 PM
MI2600's Avatar
Member# 3287
Post
I wouldn't run 9.5:1 comptression with a supercharger.
Old 04-23-2003, 01:39 PM
Chevy Thunder's Avatar
Post
Go with the 350, you mite as well take advantage of the extra cubes. Along with more hp you will also get more torque, the extra rpm of the 327 dosent make up for that.
[ April 23, 2003: Message edited by: Chevy Thunder ]</p>
Old 04-23-2003, 08:39 PM
BOBCRMAN@aol.com's Avatar
Post
Ain't no substitute for cubic inches, drop the compression to 8.5 with that huffer on her.
Old 04-24-2003, 02:38 AM
S10 Super Sleepers
Post
Whats wrong with the 9.5 to 1? That was what the manufacturer (powerdyne) recomended.
Old 04-24-2003, 05:22 AM
Honorary Redneck
Post
From the powerdyne website;
[quote]
Q: How much compression ratio can you run?
A: Again, this can vary from engine to engine but a good rule of thumb with a Powerdyne Supercharger is you can run about nine pounds of boost on a 9:1 engine. If you have more compression ratio then you need to run less boost. If you have less compression ratio then you can run more boost.
In ideal circumstances you would like to have as much compression ratio and as much boost as you can run without detonation.
Q: Which is better, high boost and low compression or low boost and high compression?
A: You are better off with a low compression/high boost combination. The combination of supercharger boost coupled with your static or geometric compression ratio provides a resultant Effective Compression Ratio.<hr></blockquote>
So I'd drop that baby down to about 8.5:1 and run upto 15psi of boost
and if your going to build both engines the same regardless, there aint no substitute for cubic inches
if your running boost you must be talking decent pistons so the 350 will rev to about the same as the 327 anyway (may be marginally less).
choose camshaft wisely, make sure you go for one designed for use with superchargers to get the best effect from it
[ April 24, 2003: Message edited by: andybird ]</p>
Old 04-24-2003, 07:26 AM
S10 Super Sleepers
Post
Question, I'm new to the 327, What about fuel milage?
Old 04-24-2003, 07:49 AM
EBlack36's Avatar
Rebuilt Excitment
Post
More than likely they will get about the same, a 350 is basically a stroked 350, both have the same bore.
Old 04-24-2003, 07:55 AM
Post
350 is a stroked 327, just fixin that for ya
Old 04-24-2003, 08:09 AM
EBlack36's Avatar
Rebuilt Excitment
Post
Fat fingers
Old 04-24-2003, 03:55 PM
Post
the 327 do have an excellent rod stroke ratio that was good for acceleration.
Foot to the floor,hair back,knuckles white.
Old 04-25-2003, 04:43 PM
pcesak's Avatar
Sakman
Post
I would go with 7.5 to 1
8.0 to 1 if you have to.
Holley Carbs has a wonderful disertation about blowers on their website under Weiand.
Grins
Pc
Old 04-26-2003, 06:45 PM
New Member
Post
ever heard the phrase bigger is better ?
