327 to 350 bearing spacers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2003, 10:09 PM
bearing spacers for small-journal crank into 350 block, also for LJ rods on SJ crank:
http://www.raceeng.com/ShowSuppliers...t=V8&subcat=BR
Old 06-23-2003, 10:40 PM
Last journal entry: More propane stuff
I am not sure but I think I remember reading somewhere that a 307 crank has the larger journals, that is if you cant find spacers
Old 06-24-2003, 10:55 AM
SAE Member; ASE Master Cert
Main bearing set to put 283/327 small journal crank in 350 case is Clevite #MS-1110H. Rod bearings are not available (as far as I know) to put 350 rods on a small journal crank, you will have to use small journal rods.
Old 06-25-2003, 02:22 AM
Thanks for the Clevite PN. That solid bearing is probably better for longevity than a spacer + bearing. The raceeng site has the same thing for rod bearings. Someone was looking for these a few weeks ago, & I ran across the site so I posted it.
Old 09-05-2007, 10:37 AM
Large journal SBC rod on small journal SBC crankshaft
Part number for large journal rods on a small journal crankshaft is:
CR867HP I think they are made by a company called King.
Do a Goolge/products search for companies selling the bearings.
Joe B.
