327 TO 350 CONVERSION - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2002, 09:49 AM
34FordPickUp's Avatar
Post 327 TO 350 CONVERSION
OK, the 327 gave up the ghost and I got a deal on a rebuilt 350. The 350 is still GEN 1 but with a one piece rear seal. 1st question: Old harmonic balancer was 6.75, new is 8 and puts the vee-belt pully out further to the front of the engine. I'd like to keep it close to the block like the 327 and re-use the existing alternator bracket. Can I just re-use the old 327 harmonic balancer? (327 was internal balance, 350 is external balance). I'm open for ideas.
Can i get the old 327 flywheel re-drilled for the new pattern on the crankshaft or would i be better of with a new flywheel? Any help would be greatly appreciated.
Old 08-27-2002, 10:23 AM
bullheimer's Avatar
NEVER use credit cards!
Post
oh boy! 327 and 350 both can use same damper what you got is an old short nosed water pump so alternator bracket is this big long flat deal on the right, you need a long nosed water pumps' alternator bracket that mounts on the left (as you look at the engine from in front) 327 balancer was press on only and was 6", 8" is better but should have a bolt in center to hold it on. just ask me, i stripped it. your alternative is to keep the short nosed water pump and find the older pulleys.
i just re read your question, yes use the old balancer but use the bolt in the 350's crank too
[ August 27, 2002: Message edited by: bullheimer ]</p>
Old 08-27-2002, 10:34 AM
Post
Well that is good news, as the 327 lived in a 34 Ford Pick-up and the alternator bracket was a custom design that mounted the unit low on the block (below the head) for engine compartment clearance. Thanks much for the help!
Old 08-27-2002, 05:38 PM
MI2600's Avatar
Member# 3287
Post
The 327 and 350 are both internally balanced. I suppose you could use a 327 balancer on a 350, but what lurks in the back of my mind is that the engineers put a larger balancer on the 350 for a reason.
Old 08-27-2002, 05:56 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Post
well well well, the 327 balancer is a press on!!!! ya learn somthin new every day at least now i know why i had such a problem trying to put mine back on!!!!!!!!!!!!!i'm lucky i didn't bend anything with that hammer and 2x4 <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> <img src="confused.gif" border="0">
