327 With 350 Crank ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2006, 05:16 PM
AMERICAN MUSCLE!!!!!!!!!
Hey Hotrodderz, i have a 327 SBC and need a crank for it. Will a 350 or 400 crank work in this engine. Also does it matter if its a 2-piece or forged. PLease give me some info on this. thank you please help me...thanks Allen
Old 03-15-2006, 05:35 PM
Wiki Edits: 31
depends on what year it is, if it's an earlier 327 than no, because it has small journals, a later 327 with large journals, might fit.
Old 03-15-2006, 05:50 PM
I think the motor is made in 1966.
Old 03-15-2006, 06:10 PM
BOBCRMAN@aol.com's Avatar
A 66 motor would be a small journal. Limiting you to a 302 or 327. A 350 could be made but, the 350 crank, main journals, would have to be turned to small journal specs.
Old 03-15-2006, 06:49 PM
he's right
the engine is a small jornal 327. the 350 crank will not fit, but if you find a small journal 283 crank it will put out 302 cubic inches. it should fit with no troubles at all!
Old 03-15-2006, 07:14 PM
302 Z28's Avatar
Problem will be finding pistons to match with that 327 block and 283 crank. 302 pistons are getting really scarce and when found are not cheap.
Vince
Old 03-15-2006, 08:04 PM
Could i buy a 327 small journal does it matter if its 2 piece or 1 piece or forged. thanks for helping me out..
Old 03-16-2006, 04:55 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Having torn apart literally scores of small journal 327's I have yet to see one that DIDN'T have a forged crank. I have heard of cast cranks in small journal 327's but have never seen one. By 1 and 2 pc. are you referring to the rear main seal? All '55-'86 small blocks were 2 piece.
Old 03-16-2006, 07:25 AM
302 Z28's Avatar
GM Performance parts makes an adapter that will allow you to use a crank designed for a one piece rear main seal in an earlier two piece rear main seal block.
Cince
Old 03-16-2006, 01:07 PM
Hippie's Avatar
Cince
I thought that only worked on large journals.
Old 03-16-2006, 08:20 PM
302 Z28's Avatar
Oops, you might be right.
Vince
Old 03-17-2006, 05:59 AM
GoneNova/406's Avatar
eagles 9000 serie cranks for a basic 350 are $160.00,if you contact them and pre arrange it,i am quite certain for a few dollars more they will grind the rod journals down to 2".
Old 03-17-2006, 08:49 PM
Hello found one on the internet but its out of a 69 327 will this still work. thank you
Old 03-17-2006, 09:52 PM
here is what i found on mortec.com 3941174....307,327...cast....medium journal...3.25" stroke my motor is made i think in 64. will this work.
'69 327 crank is a large (or medium size if you will) journal. You need to find a pre '68 crank.
400 destroked with a 327 crank dirtracer21inc Engine 25 08-19-2008 01:29 PM
Differences between a 307, 327, 350? Smoked Rubber Engine 9 12-08-2004 05:15 AM
327 block 350 crank neverstopped Engine 3 10-03-2003 08:55 AM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
327 or 350 ? HotRodS10 Engine 3 05-06-2002 08:15 AM
