Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-20-2004, 10:13 AM
pete379 pete379 is offline
327 in 88 Truck
I think i have some pretty good friends. I have a buddy that gave me a 327 block and i was wondering will it be a good engine to replace my tired 350. I really want to use this engine, and was wondering how i need to set this engine up. The truck is daily driven, and i want it to be realiable with around 300-350 hp.
I plan on ordering a rebuild kit from paw. Someone told me to use the vortech heads and manifold, and appropriate carb. I also need to know what headers to use and i would like to keep evrything from my old 350(a/c, p/s, etc.)PLEASE help i'm ready to start building
Old 10-20-2004, 10:21 AM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
re: 327 in 88 Truck
After you do all that to the 327, it will feel like the stock 350.
You would be way ahead to do all that to your 350.
Troy
Old 10-20-2004, 12:58 PM
killerformula's Avatar
killerformula killerformula is offline
Moderator
 killerformula's barnstar
re: 327 in 88 Truck
correct me if I'm wrong, but if this is a large journal block that's nice and ready to go, couldn't he throw in a 350 or even a 400 crank and make the appropriate motor wiht the block (350 or 383?)
K
Old 10-20-2004, 01:09 PM
Lonestar's Avatar
Lonestar Lonestar is offline
"May the Schwartz be with you"
 Lonestar's barnstar
re: 327 in 88 Truck
What kind of truck?
What's wrong with a 327?
Old 10-20-2004, 01:15 PM
re: 327 in 88 Truck
Its a 1988 chevy 1/2 ton with a 350 tbi unit. I figured that i could build something totally different and be pretty reliable with adequate hp. Plus the block is free and really good shape.
Old 10-20-2004, 01:23 PM
Lonestar's Avatar
 Lonestar's barnstar
re: 327 in 88 Truck
Is it a small or large journal block?
Old 10-20-2004, 02:46 PM
re: 327 in 88 Truck
I'm not sure i'll find out. I think large, if not is it worth building to my my specs. I figured i could add a decent cam, heads ,pistons, etc. to make a different combo in a 88 truck. What mods do i need to do make it work with my tranmission. Its the turbo 700.
Old 10-20-2004, 02:50 PM
Moderator
re: 327 in 88 Truck
it will bolt right up to your mounts and your trans. No mods.
K
Old 10-20-2004, 02:51 PM
Lonestar's Avatar
 Lonestar's barnstar
re: 327 in 88 Truck
The 327 is a good engine and can run along side a 350 any day...it just has a narrower prefered range of operation and you have to taylor the drivetrain to match.
What are your specs?
Old 10-20-2004, 02:55 PM
Ghetto Jet's Avatar
Ghetto Jet Ghetto Jet is offline
pic of my Cobra should be here
re: 327 in 88 Truck
K
Thats exactly right. All opinions aside, it will bolt in just fine. Trucks are heavy, going mild you'll miss the bottom end you would have with a mild 350 compared to a mild 327.
Old 10-20-2004, 03:54 PM
Lonestar's Avatar
 Lonestar's barnstar
re: 327 in 88 Truck
I do agree with Ghetto Jet, the 350 would be a better suited engine for a full size brick. I would rebuild the 327 for a lighter more aerodynamic car and rebuild your 350 for the truck.
Old 10-20-2004, 10:15 PM
troy-curt's Avatar
re: 327 in 88 Truck
There is no substitute for cubic inches. Why do you think GM dropped the 327? Mo power, same money.
Hey, I'm not knocking the little 327, I've seen some nice running ones. I'm just saying that you can do the same things to the 350 that you are going to do to the 327 and have gobs more power.
You could probably sell the 327 to some one restoring a pre 69 for enough to build the 350.
Troy
Old 10-20-2004, 10:17 PM
re: 327 in 88 Truck
I'm not sure as what i'm going to throw into the block. I know i need the torque move the truck(cam, heads,etc.). Do yall have any suggestions as tho what i should stuff it with? The truck is daily driven with some interstate use. I'm thinking about vortech heads if that'll work, and the matching edelbrock cam,intake,and carb(the package deal in the jegs catalog).
Old 10-20-2004, 11:02 PM
Robinson Robin Robinson Robin is offline
re: 327 in 88 Truck
Troy
I couldn't agree more you will need to hop it up just to reach the power of stock stock 350. You'd be much farther ahead just to start with the 350. People go to trouble stroking 350's to 383 for this very reason, to go from a 350 to a 327 you will be taking a step backwards.
Old 10-20-2004, 11:06 PM
musky2 musky2 is offline
Drive your truck and in the mean time be building the 327 ; you would never know the difference If that 327 had a 350 breather on it . There is not enough difference to worry about.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
