327 Balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2010, 12:05 PM
327 Balancer
I bought a rebuild '67 327 and it had the Original Harmonic Balancer on it (6.1"), it's not in the best shape so i'm going to replace it, Which size of balancer should i put on it? the engine has not been balanced
Old 08-03-2010, 03:45 PM
techinspector1's Avatar
Wiki Edits: 326
According to Damper Doctors, there are 8 different dampers for the the 327. Chevrolet used 3 different timing mark locations, Noon, 2:00 O'Clock and 2:30 O'Clock, so if you don't know, you can install the wrong clocking damper with your chain cover tab and your ignition timing will be off.
What would I do? I'd box up my damper and ship it to the good doctor for a rebuild. He will disassemble the damper, install new elastomeric material between the hub and the inertia ring, clock them properly and press the assembly together under hydraulic pressure.
The other reason to rebuild an OEM unit rather than purchase an aftermarket unit is that the hub isn't always bored to spec. You guys are aware of all the junk coming from offshore and some of these damper units are no exception. One thing about re-using your rebuilt damper, YOU KNOW IT WORKS.
Installation can be eased by putting the entire damper into a large pan of water and bringing it to 200 degrees, then pushing the hub onto the crank snout with cooking mitts. It should slide on easily, particularly if you use some ice on the crank snout before assembly, eliminating the hassle of tearing threads out of the crank with an undersize hub or having the unit not do its job from being bored oversize.
http://www.damperdoctor.com/Merchant...egory_Code=CHE
Once you have a valid damper in place, verify its validity with the timing tab by using the procedure outlined here.....
http://www.crankshaftcoalition.com/w...op_dead_center
You have no way of knowing if the last guy who worked on your motor kept the stock tab and damper matched up.
327 harmonic balancer install camaro123 Engine 0 01-01-2010 10:40 AM
68 327 motor, harmonic balancer 2002chevy Engine 8 09-14-2008 04:38 PM
chevy 327 Harmonic Balancer Size? 70Z28 Engine 5 12-17-2006 08:30 PM
327 balancer 70gs455 Engine 7 02-24-2004 02:40 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 05:10 PM
