327 Block Numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2005, 10:41 PM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
327 Block Numbers
I finally took possesion of a 58 Chevy 2 Door. At some point in it's life someone droped a 327 in it.
Where do I locate numbers to find out what 327 I have?
A quick look after getting it into the garage all I could find where firing order numbers.
Old 11-17-2005, 11:17 PM
TechnTool's Avatar
OldSchool MotorHead
First, wash the engine off really well. then take the valve covers off and look for a casting number on the top of the heads. then for the block, look along the back of the engine for the casting number, near where the trans bolts up, or along the front near the timing cover. You need to know the #'s for the block and the heads in case there is a mismatch.
Old 12-02-2005, 09:36 AM
58Chev's Avatar
OK, finally had some time... Can someone lend some insight??
Block # 3970010 327/350
Head # 3785886 or so I thought??? All I could find on the net that was close was 3795896
Intake # 3875954
Engine Sufix Number is where I need the most help....
K0529CNV
With the block number I find references to 327 or 350?
The head number is confusing also???
ThanX
Old 12-02-2005, 01:00 PM
DoubleVision's Avatar
1970 CNV 350 tur hydro trans. 250 2 Caprice
Old 12-02-2005, 02:09 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Consult the Hotrodders Knowledge Base, we have a variety of Chevrolet engine tech data pages listed.
Here's a direct link: Chevrolet Engine Technical Data.
Let me know if that's helpful. Or, if anyone knows of any other similar pages, let me know and I'll add them to the Knowledge Base so that we can get them all listed in one place.
chevy block question joesnova2 Engine 15 05-01-2007 10:20 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Tall block Chevy 366-427 need some numbers? 81elcamino Engine 3 01-21-2004 06:48 AM
327 crank in a 400 block??? chevyelc81 Engine 9 11-20-2003 05:27 PM
1968 sbc 327 I.D.? Coleman396 Engine 4 08-21-2003 06:15 PM
