Thread Tools Search this Thread share on Facebook
  #1
Old 04-01-2009, 09:11 PM
loxhotrod loxhotrod is offline
327 boring
I have a "69 327 that has been bored .040 and the crank is turned .010. I have been told that it is not good to go more than .030. To keep this block I will need to go to .060. Does anyone have any knowledge as to the possible problems with doing this. I will also need to turn the crank, probably another .010. Any info will be greatly appreciated.
Register now (free) or login to remove ads
Old 04-01-2009, 10:23 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
There are probably several hundred thousand small block Chevys out there running everyday with +0.060" blocks and -0.030" cranks.
Old 04-02-2009, 05:48 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
CNC Blocks Northeast
Have the block sonic tested if its going to be a performance build as that is the only true way to tell if you have a good peice as it takes the guess work out!!!!!!!!!
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "327 boring"
ThreadThread StarterForumRepliesLast Post
swap 283 to 327 impala 1967ricolalaEngine1103-03-2009 11:28 AM
327 large and small journal motors31 Ford CoupeEngine909-08-2008 12:09 PM
327 '89 Trans Am GTA suggestions3rdGenFreakEngine206-29-2007 07:45 PM
Chevrolet 327TEEMCDEE9552Engine1506-09-2007 08:22 PM
help make my 327 angry!!!70chevelle327Engine4104-24-2007 05:33 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
