327 bottom ends? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 11:25 PM
MAKE EM STICK AND E.T'S QUICK
327 bottom ends?
im building a 327 casting number 3914660 i know this was an impala motor and all the 327s came with dif heads and intakes. but i cant seem to dig up if they all had the same bottom end? mines a lg journal 2 bolt main which i like so when i rebuild the bottom i can splay the caps. but im trying to find out what compression it was stock and what it will be with my 462 casting 2.02 heads? but cant seem to find this info anywhere online. andyou guys always have thr RIGHT answers.thanks. from what i understand the 327s differed in cams intakes and heads but know nothing of the bottom ends it has 4 valve relief pistons if that helps.
Old 01-21-2011, 03:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A SBC 327 w/64 cc chambers and FT pistons w/a 0.040" quench will be a little above 9.5:1 CR.
There were 327's w/large journal (aka “LJ”) forged cranks, but they're few and far between. '68 was the only year for this, IIRC. '67-back were forged SJ cranks.
327 engines could be LJ (cast or forged) or small journal (forged only), the SJ rods had 11/32" bolts, the LJ rods had 3/8" bolts. Rods earlier than about '64 had "spit holes".
Large journal blocks could be 2- or 4-bolt mains. 327's were 2-bolt. Only 302, 350 and 400 blocks could be 4-bolt (but not all were).
Old 01-21-2011, 04:53 AM
thanks i belive i have the forged crank. also with no threads for bolt in crank snout. iv been installing dual idler timing gears tonight and have to grind down the cam button and axle of the power idler to clear my timing cover. any suggestions for not taking to much off?
Old 01-21-2011, 04:54 AM
Old 01-21-2011, 06:52 AM
CosmikDebris's Avatar
Last journal entry: 1974 S&W
Are you using a stock cover? If so why not go to a after market cover to avoid grinding on the gear set. I have a extra Eddy cover, I can measure the depth if that will help.
Old 01-21-2011, 09:13 AM
1971BB427's Avatar
Maybe mt 327 is a fluke, but it's from a 1967 Chevelle SS and it's large journal forged crank.
Old 01-21-2011, 01:27 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Must be a fluke because the only large journal that came in 67 was the 350 used in a Camaro.
Old 01-21-2011, 11:37 PM
that would be helpfull but either way the faces of all 4 gears need to be flush with each other. and when they are flush the power idler axle touches the block and needs a min of .005" clearance. and my cover seems to be a stock replacement chrome chevrolet cover, also the cam button touches the timing cover slightly
Old 01-21-2011, 11:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can tell a forged crank from a cast crank easily by the width of the parting line. See image below.
I'm going to go out on a limb and say I do not think GM made a 327 LJ crank w/o the threaded damper bolt hole. I do not know this for a fact, however I did own a LJ cast crank '68 327 that was w/o the threaded hole.
I always suggest a gear drive not be used. Instead, use a quality double roller timing set and be done w/all the monkey motion of that gear drive and the installation of it.
OEM CAST CRANK (thin parting line)
OEM FORGED CRANK (wide parting line)
OEM Cast on Left, Forged Aftermarket on Right
Old 01-22-2011, 01:28 AM
i hear that alot hhonestly. about the chain instead of gears. but the way i see it the gears are stronger and i really enjoy the whine of the tightly meshed gears. and another big factor is i am on a limited budget and the noisey gears were a gift from my wife so they most def. will be used. i love her now that i think about it. lol
Old 01-22-2011, 05:26 AM
Looks like grinding or milling is the solution also I don't think the stock cover will hold up to the cam button w/o reinforcement. I will post the measurement of the eddy cover today
http://static.summitracing.com/globa.../sum-g6700.pdf
Old 01-22-2011, 10:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
... the noisey gears were a gift from my wife so they most def. will be used. i love her now that i think about it. lol
You need say no more! More power to you both.
350 bottom end JohnyR17 Engine 4 10-30-2006 11:38 AM
What bottom end to use NovaSS350 Engine 0 06-13-2004 03:50 PM
bottom end astrops Transmission - Rearend 1 05-24-2004 04:57 PM
What is bottom end? Rubberman2003 Engine 3 07-13-2003 02:33 PM
want more bottom end mr.chevelle Engine 14 07-12-2003 09:59 PM
