327 build
i am going to build a 327 for my wifes 92 s-10 blazer. what will set up can i use to give me the most steetable power? it has a 700r4 trans, i want to put a stall in it to but i dont know what size yet. i want it to be really strong, but i dont know to choose for parts. thanks
What is your budget and what parts do you have already?
327 build
block, gm stock crank, i have some camel hump heads, but dont know if i want to use them. because they dont have the assy bracket holes.
What is the vehicle being used for? Street 100%? Strip 50/50?
327 build
a little of both
If you want a real screamer you are going to need forged rods, and forged pistons, I like gapless rings, and a good set of aftermarket heads.
A roller cam will let you get pretty aggressive withought sacrificing bottom end driveability. A 2000+ stall converter will also open up your cam selection as well as a set of gears in the 3.55-3.73 range...depending on tire size. Flat top pistons with two valve reliefs, and a set of modern 64cc heads will allow you to run more compression on pump gas. If you have 4000 bucks you can build a really nice dual purpose motor, for 6000 it could be something really spectacular (blower maybe?). In that small vehicle it won't take a whole lot to get it moving. My advise would be to start out with a really stout shortblock, with forged internals. That way you can put a 250 shot of nitrous on it at the track! |
| Horsepower/torque from 327 engine build?? | J327HO | Engine | 37 | 08-17-2011 07:23 PM |
| 200-4r experts - build questions - Which core is best to build on? | Warrant | Transmission - Rearend | 7 | 10-09-2007 07:36 PM |
| Build my 327 | chewyscool | Engine | 11 | 08-03-2007 10:28 AM |
| 383 Build Questions | Mustangsaly | Engine | 3 | 06-14-2005 09:53 AM |
| build a 302 or 327 | dadsgp | Engine | 2 | 08-25-2004 11:18 AM |
