Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 build help
Thread: 327 build help
Old 01-03-2010, 12:43 PM
automotive breath's Avatar
automotive breath automotive breath is offline
Swap out the rods with the scat small journal I beam rods.
Properly prepared vortec heads would work well or there are plenty of
aftermarket choices. Runner and chamber volume are critical. Intake runner
volume in the 170 - 180 cc range. Set up the piston to head clearance near
0.040", use combustion chamber volume to achieve the desired compression
ratio.
Camshaft selection will depend on the intended RPM range.
