Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 build help
Thread: 327 build help
  #44 (permalink)
Old 01-04-2010, 03:15 PM
Rickracer's Avatar
Rickracer Rickracer is offline
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by ap72
...I'm curious though, what would you change? ...If you could give me some details I'm all ears.....
I used to do a lot of porting, my 492s got the full treatment, the oval ports on my 427 flowed more than a set of stock square ports with MUCH better velocity and low end, did quite a few circle track heads for another shop here in town, but that was years ago, and they were a lot different animals than the Vortecs. Dennis, my machinist, would be the guy to ask, there are companies that make CNC plots from his port work for some of the import stuff. I just know he's told me several times that almost anything done to the port walls and bowls hurts flow, not help it. Chevy really did their homework on the Vortecs.
