327 carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 04:14 PM
327 carb
I have a 1967 327 chevy roller cam,dome pistons,202 heads what would be a good carb i have a chance to get a great deal on a HOLLY 670 carb would this be good? or ????
Old 04-30-2011, 09:15 PM
327 carb
That carb is about the cfm rating you need for a 327. However, don't get a Holley Street Avenger carb.
Ron
Old 04-30-2011, 10:00 PM
327NUT's Avatar
Look at the Quick Fuel carbs, they can build one for your specific engine needs. I've had 2 of them and they are very nice well built carbs, also their tech guys will always answer the phone. www.quickfueltechnology.com
Old 05-01-2011, 01:48 AM
DoubleVision's Avatar
Quadrajet gets my vote.
Old 05-01-2011, 06:58 PM
lg1969's Avatar
Google "Tunnel Ram 406"
It depends the kind of car it is. What type of transmission and rear end gear ratio and tire size. What rpm range you are you looking at.
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
Carb daves1969mach Engine 2 08-04-2004 10:11 PM
