Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 chevy really all the hype?
  #25 (permalink)
Old 02-06-2013, 09:34 PM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Don't believe everything you read on the web!!
Yes, A 283 is like a bored 265, a 302 is like a bored 283, and a 327 is like a bored 265 or 283 and on to the 350 But if you read that on the web you would think a 350 is a bored 265 block casting!
The easy way to build a "301" is to use an early 327 and a 283 crank. We did that in the 60s but that's not the 302 of legend.
DZ302 and YZ302
When you see fully machined blocks from machinist on the web passing off there 3932386 casting converted 327's & 350s As Genuine Z28 DZ YZ 302's,LT1's,High Perf. 300 350 370 375HP 350's ask them what the #'s on Main caps are. If there Not the Nodular Forged (Denoted by the Capped letters "NF") "2482"s then they are FAKE!
Camaro Hi-Performance: Vehicles: The Old Reliable
Jerry MacNeish and the legendary Bill "Grumpy" Jenkins at the 1994 NHRA Keystone Nationals, Maple Grove, PA.
TECHNICAL DATA
VIN number 124378N411100
Build Date 04A (first week of April)
Color Corvette Bronze
Interior Code 712, black standard
Car Shipper Shipped on April 11, 1968 to Ammon R. Smith Auto Company, York, PA
Engine Data Cubic Inches, 302
Cylinder heads #3917291, completely stock, no porting allowed!
Stock rocker arms & valve springs
Intake 302 aluminum intake, casting #3917610
Carburetor Holley, #4053, 780 CFM 4bbl
Camshaft Crane, .480 inches lift, 272 degrees duration, valve lash, .016-.016
Pistons GM 302, .030" oversize
Horsepower 456 @7700rpm
Rear Tires 9" x 30.0" Hoosier's
Rear axle & ratio 12-bolt, 5.57 Richmond Pro Gears
Clutch 10 inch, three finger from Advance Clutch Technology
Shift Points 8200 RPM
BEST ET 10.80 @122.30mph
05 stock champion
That's old skool: Stock class stock heads' stock rockers and springs, Shifting at 8200, 456 hp 7700rpm and still will make your heart stop today! Thus called a legend!!!
Jester
