i appreciate everybodys opinions and sharing the knowledge and or stories.... i know the 327 was pretty stout back then but i guess in these new days people are running 355 and 383's , 406's all over the place....
but one serious question ive always wanted to ask... Why do you think it was replaced with the 350????????
And you could pull up to the pump and get good gas.
Do some research and reading in your spare time (not meant sarcastically).
Check out Chevrolet small-block engine - Wikipedia, the free encyclopedia The 283 was an overbored 265. The 327 was a stroked and overbored 283. Hence the reason for the early small journal 327's. I think GM realized they could restroke the 4.00" bore 327 to 3.48 without any block clearance issues, so why not take advantage of the longer stroke and rod to stroke ratio and build 350's. I've read in several places (not known to be fact) that the 307, that came out in '68 was the result of alot of 283 blocks 'laying around' at GM that could use the newer 327 cranks. And, again from what I've read, the 302 was a response to racing displacement rules. Now, for the 400, I don't know, maybe GM wanted lead the pack for small blocks. Of course this is my opinion. But one thing that GM did was maintain a very similar platform that led to alot of interchangeable components amongst different displacements and model years, which is real good for us and made the SBC very cheap to build. For example, check out the pricing on building a stage II or stage III 455 Buick or hot 340 or 383 Mopar. AGAIN, just my opinion. |
327 Vs 350
Back in the early 60s,maybe some of the other guys remember better than me. GM built 5 x377 cube stroker small blocks for the vette racing program.I think they were put in a 63 vette? over in Europe the Germans were well into developing fuel injection for their road cars and were able to find more power that way,better mileage was more important in Europe than here. R&D will try many things and market some of the successes The 350 chevy came out in 1967 in the Z-27 Camaro.not sure what the 396 was designated as? the 302 of course was Z-28 sorry,useless bits of info tossed in a random order |
The Chevy 302 (301 as it was called in the day) engine was a 283 CI engine bored to 4".
The SB Chevy 283 engine bored out to 301 CI was the top dog SB Chevy engine until Chevrolet introduced the 327 CI engine in 1962. My first street machine when I graduated high school was a yellow '56 Chevy Del Ray 2-door sedan with a 265 CI Power Pack engine, 3-speed with OD. I rebuilt and installed a 1957 Chevrolet 283 CI engine in the '56 Chevy. My 283 CI engine was bored to 4.00" for 301 CI and I installed a 4.56:1 rear gear. I wrecked my '56 Chevy on December 23, 1962 and installed the 4.56 rear end in my 1959 Impala 2-dr. HT with a 4-speed. |
My '56 Chevy Del Ray was MINT, even for 1962. It was equipped with a 3-speed floor shifter from Honest Charley Speed Shop and a Sun 5000 RPM tachometer mounted on the steering column. I rolled it on a icy road two days before Christmas 1962. I bought a beige 1959 Impala 2-dr HT with a 283 engine and a 4-speed six months later with a $500 loan for the down payment from my father. I salvaged the 4.56 Posi rear end and later used it on my '59 Impala. The only engine parts I salvaged from my '56 Chevy was a pair of Corvette valve covers.
Of all the cars I have owned, I liked my lemon yellow '56 Chevy Del Ray the best. It came from the factory with a 4.11 rear end because it had 3-speed transmission with OD. I replaced the 4.11 open rear end with a 4.56 Posi Traction using new GM ring and pinion gears. |
Don't believe everything you read on the web!!
Yes, A 283 is like a bored 265, a 302 is like a bored 283, and a 327 is like a bored 265 or 283 and on to the 350 But if you read that on the web you would think a 350 is a bored 265 block casting! The easy way to build a "301" is to use an early 327 and a 283 crank. We did that in the 60s but that's not the 302 of legend. DZ302 and YZ302 When you see fully machined blocks from machinist on the web passing off there 3932386 casting converted 327's & 350s As Genuine Z28 DZ YZ 302's,LT1's,High Perf. 300 350 370 375HP 350's ask them what the #'s on Main caps are. If there Not the Nodular Forged (Denoted by the Capped letters "NF") "2482"s then they are FAKE! Camaro Hi-Performance: Vehicles: The Old Reliable Jerry MacNeish and the legendary Bill "Grumpy" Jenkins at the 1994 NHRA Keystone Nationals, Maple Grove, PA. TECHNICAL DATA VIN number 124378N411100 Build Date 04A (first week of April) Color Corvette Bronze Interior Code 712, black standard Car Shipper Shipped on April 11, 1968 to Ammon R. Smith Auto Company, York, PA Engine Data Cubic Inches, 302 Cylinder heads #3917291, completely stock, no porting allowed! Stock rocker arms & valve springs Intake 302 aluminum intake, casting #3917610 Carburetor Holley, #4053, 780 CFM 4bbl Camshaft Crane, .480 inches lift, 272 degrees duration, valve lash, .016-.016 Pistons GM 302, .030" oversize Horsepower 456 @7700rpm Rear Tires 9" x 30.0" Hoosier's Rear axle & ratio 12-bolt, 5.57 Richmond Pro Gears Clutch 10 inch, three finger from Advance Clutch Technology Shift Points 8200 RPM BEST ET 10.80 @122.30mph 05 stock champion That's old skool: Stock class stock heads' stock rockers and springs, Shifting at 8200, 456 hp 7700rpm and still will make your heart stop today! Thus called a legend!!!Jester |
IMO: Don't forget in the beginning of 1970, Emission level was getting tighter it was coming into play.
That is why a 283 was replaced with a 307, 327 was replaced with a 350, 427 was replaced with a 454. And the 305 has a smaller bore but same stroke as the 350. It seem the longer stroke motors produce less emission. Chevy was in a hurry of building 302 for trans-am racing that was limited to 305. that's another story. Because of cars were getting heavy chevy needed a longer strokes motors in order of getting more torque. |
yes it was, remember back when the 327/350 came out.. the tire tech wasn't what it is today.. today we are spoiled with rubber that even slicks of the day didn't have..
the 327 lack of hugy low end helped it. get the car out of the hole.. and the rpm range worked great with the transmissions aval. then.. 2speed powerglide or 4 speed wide stick.. I've driven both a 327 and 350 vettes with sticks.. and the 327 was way more fun.. |
I saw a test comparing a stock high hp late model Vette with a 67 Vette ( I think an L 88?) in the 1/4 and 0 to 60 times! The new Vette beat out the 67 but the 67 had stock tires 7 inch tread the new vette had stock tires but with a really wide tread and it also had stock traction aids that the early Vette didn't come out with!! I watched that and thought it was so unfair!!!!!
![]() Its like the stock factory muscle cars of the 60s, and 70s they came out with stock tires of a tread pattern of 6 to 7 1/2 inches with bare bones suspensions, The new muscle has big tires big tread,traction aids etc ! and to compare the 2 to 1/4 and 0-60 times with data from 60s and early 70's compared to new car test data today is Ludicruse! But you see it over and over again ![]() Jester |
My associate, Randall Brock, purchased a slightly used 1967 Corvette 427 L88 in 1969 for $6,000!
I drove his 1967 Corvette 427 L88 a few times and it was the fasted street driven vehicle I have ever drove or even rode in. The Corvette could turn 11.00 sec. ETs consistently with some good bite. R. Brock also owned a 1969 Dodge Charger with 426 Street Hemi with an automatic transmission and his L88 Corvette could blow the Charger's doors off. Randall Brock's 1967 L88 Corvette 427 CI engine 430 HP at 4600 RPM (advertised) 560 HP at 6400 RPM Total production: 20 (14 known to exist today) 850 CFM Holley double pumper Cast iron heads White with black interior Convertible No radio available No spark plug static shields M22 Muncie 4-speed K66 TI ignition Side pipes 4.56 Positraction Built at the St. Louis MO Assembly plant The unconfirmed rumor was that Brock's 1967 L88 Corvette was ordered by the TV host Dick Clark but when it arrived without a radio, Clark refused to accept it. In 1971, Randall Brock traded his '67 L88 Corvette roadster for a 1967 Pontiac Firebird 400 convertible which I acquired a year later . The '67 Firebird had 3500 miles on the odometer. The new owner of the '67 L88 Corvette lived in San Antonio TX and he turned it into a race car and it was never licensed again. It has disappeared from history. Last edited by MouseFink; 02-08-2013 at 05:26 PM. |
But. In the real world often the relationships and dimensions of component just don't work together, one could think 312 Y block Ford as an old example. Other times you just hit it. The 327 was one of those times, it seems the 4 inch bore in any engine is a gift that allows valves big enough to feed the cylinder. To me it's almost a magic dimension; it's hard to think of a poor running 4 inch bore motor from any manufacturer. Sure you can load 'em up with emissions and mess them up, but generally they've proven to be a family of well, if not superlative, performance engines. All 327s have a good rod length to stroke ratio, the performance engines got forged cranks; they also got well proportioned to slightly large ports, big to bigger valves, high compression dual quench heads. Just a lot of stuff that works well together. But against an equally prepared larger engine like the 350 the 327 and 302 for that matter need to have a drive train that adjusts for their need to turn more RPM for equal power. So the end result is as much matching the vehicle and driveline characteristics to the engine’s characteristics. One has to keep in mind the primary driver behind engine size evolution is the need for more torque to move grocery getters, sell these is what pays the bills over at GM, Ford, and Chrysler. Performance sells to pretty small crowd so even if mom and pop came in to the dealer on Monday following some big national raceway win the preceding Sunday; it was more likely they left with a 250 horse 327 in a station wagon than a 360 horse 327 in a Corvette. So the performance arm of the company most always makes due with what's up for mom and pop production. So as the 283 was a torque search over the 265, the 327, 350, and 400 were from the same intention on the part of Chevy; more torque to cruise more weight and power consuming gadgets. I won't even comment on some the stuff they went to in the interest of emissions like 262 or 267, these tiny bore motors are attempts to use Voodoo to solve engineering problems and everybody went down that road to the same end. Bogie |
| Annular boosters - the real deal or marketing hype? | Mad Maggot | Engine | 18 | 11-22-2009 03:13 PM |
| are they all hype???? | neverfastenuff | Engine | 20 | 05-06-2008 04:31 PM |
| QuietCar Sound deadener real or hype? | JonRunaas | General Rodding Tech | 4 | 04-10-2008 08:07 PM |
| Marketing {hype} | Ole JIM | Hotrodders' Lounge | 25 | 08-25-2006 04:51 PM |
| Oil additives, hype or truth? | 4 Jaw Chuck | Engine | 11 | 03-17-2003 09:14 AM |
