327 Crank install
I Am getting my block from the machine shop tomorrow, and i am going to put together the crank and check to see if tolerences are within spec. Al parts are forged, crank is a large journal GM 327 crank, it was just ground .010/.010 under. The block had studs put in and got line honed.
This motor will see 7600rpm ever so often, and at least 6000 quite often. What are all the tolerances that i need to check? Does anyone have a link or something for a list of specs for a performance build?
Cam is isky cam 3000-7600 oval track. I am planning on getting some rhs proaction 200cc heads, forged KB pistons, and scat i-beam rods.
Thanks, josh.
