327 with double hump heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2007, 06:59 PM
got a 327 with2hump heads for 250 dollars! goin in the nova. it came out of a 68 camaro, and is either a 210 or 275 horse motor. never bored. comes with origonal intake. i am considering putting the 350 horse cam in it, what do yall think
Old 02-09-2007, 07:25 PM
double humps
If you are running a standard trans. you will be okay with the 350 hp and the saturday night special idle quality , with automatic you need a stall converter due to the low vacuum it will carry approx. 10 inches.The 350 hp cam only makes a small amount more hp then the 300 in real dyno numbers.20-25 hp more but the torque is almost identical .I have dynoed both and I would go with the 300 hp .
Old 02-09-2007, 07:35 PM
so i should go with the 300 horse cam huh? will this have any sound to it? what about idle? keep in mind im going with a th350 with a full manual valve body.373 gears also. running super40 series flowmasters as well turned down after the front seat.
Old 02-09-2007, 07:51 PM
350 hp cam
You will like the sound of the 350 hp and you have the gears and trans too make it work, enjoy ! Sounds like a fun ride .I want a ride .
Old 02-13-2007, 12:25 AM
your motor is a 275hp version since it has the camel hump heads. THe 275hp and 300hp motors use the same cam if I remember right. the 350hp cam will work fine but it`s a little out dated. Check out Lunati`s Voodoo series cams. the 262 or even the 268 voodoo would be a great cam for your motor.
help please!! double hump heads DB fusmc Engine 10 06-17-2007 04:33 PM
max valve lift for 1967 Chevy 327 camaro double hump heads?? kuhn-77 Engine 1 08-18-2006 06:12 PM
What's so great about SBC double hump heads? frankenvette Engine 3 07-24-2005 08:41 PM
best cam for double hump heads sam83k10 Engine 13 03-27-2005 11:58 AM
old double hump heads chale24088 Engine 8 06-20-2002 12:37 PM
