327 double hump heads on a 350 small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2006, 04:40 PM
Could I get some ideas? The heads I am looking at are 2.02 or 2.20 intake (I'd have to look it up again) 1.60 out. Dad said 1.94 were the ones I need. Is 327 heads on 350 block good idea?
Old 02-19-2006, 04:53 PM
They're an older head, but they still run pretty good. If they are the early camel backs then they won't have the end holes for the accessory attachment. If they are the LT-1/Z28 heads they will. The early heads had 1.94 or 2.02 intake valves. The later heads only had 2.02 I believe. Both should have a nominal combustion chamber of 64cc. I personally prefer the 64cc head to the later 76cc smog heads. If they're in good shape and reasonably priced go for them. Otherwise there may be more economical choices out there once you add in the price of a complete rebuild.
Old 02-19-2006, 08:09 PM
Mighty Mouse S-10's Avatar
Cleverly disguised as grownup
Last journal entry: Hollman & Moody
How much do they want for the humps? Cause unless they are almost free, you could find better heads for less than it will cost you to have new valve guides and hardened seats installed. Think about some bone yard vortec heads.
Old 02-19-2006, 08:59 PM
Heads are on ebay for 75.00. Would I need to buy a intake manifold with it? I like the cross flow intake
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
Bought 350 block and came with free heads('62 327 75cc????) 89SDime Engine 7 01-14-2006 05:50 PM
350 chevy small block ?s 350MC Hotrodding Basics 19 06-16-2004 10:08 AM
Double hump heads GearHead69 Engine 2 10-26-2003 06:00 AM
Ok, I need to know what makes double hump heads better lord Hotrodding Basics 9 10-18-2003 01:22 PM
