327 Dwell - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 08:49 AM
super_silent's Avatar
327 Dwell
Hello everyone,
I'm trying to get a 67 camaro (327 4bbl) that I just bought tuned as it has a few issues I'm trying to correct.
The car had a really strong gas smell and also bogged when accelerating. I replaced the carb with a new one(rebuilt) and solved the gas smell (leak in fuel line at carb)
adjusted carb and reset timing, still has a very slight hesitation occasionally when accelerating but runs alot better now. Anyone know the dwell setting for this ? I will eventually switch to pertronix but I'd like to get it running properly for now.
Thanks
Old 09-03-2006, 09:39 AM
Jmark's Avatar
Factory dist dwell setting is 28-32 degrees. Re-check the timing after setting the dwell. Also make sure the vac advance is working too.
Old 09-03-2006, 02:07 PM
Thanks Jmark .
setting points on sb chevy frackster66 Electrical 14 03-22-2008 11:33 AM
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
help make my 327 angry!!! 70chevelle327 Engine 41 04-24-2007 05:33 PM
327 build up using 1964 and earlier parts ONLY chopperimpala Engine 23 10-06-2005 01:07 PM
327 rebuild help. SUGGESTIONS PLEASE DeezImpala Engine 1 06-24-2002 09:06 PM
