327 engine bolted to T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2013, 05:47 PM
i have just recently bought a 327 for $500. i put new gaskets in it (blown head gasket). and tried to put my tranny to my engine and the flex plate bolt holes do not line up with my torque converter bolt holes. the engine is a 1967 version and the tranny is a TH350 1985 version. is there anyway i can get the 2 to go together with out lost of money lost?
Old 02-08-2013, 06:27 PM
BOBCRMAN@aol.com's Avatar
After market replacement flex plates usually have two patterns on them. One will fit your convertor.
Old 02-09-2013, 02:09 PM
i actually got it to work. my issue was that i was trying to bolt the tranny up to the engine inside of the truck instead of out, causing the torque converter and flexplate to not line up correctly.
engine size 350 or 327? coradjes Hotrodding Basics 12 04-05-2013 12:54 PM
Chevy Engine 302, 327, 350? Chevy67Chevelle Engine 11 12-06-2010 04:21 PM
C4 trans bolted to 1996 5.0 engine, which starter? V8juggernaut Transmission - Rearend 4 09-13-2010 09:00 PM
engine timing sbc 350 or 327 don't know Carlos9 Engine 4 06-10-2009 04:56 PM
350 - 327 engine appearance differences sattwood Engine 9 12-08-2003 10:50 PM
