#1
327 engine codes
I am looking at 327 with the following codes Owner says it runs I am planning on replacing rings,bearings,doing valve job on heads is it worth $ 800.00 any problems I should look out for Thanks,Mike 3903352/to811ha/3805393/3890462 d/h
Register now (free) or login to remove ads |
#2
If the to811ha is the number on the pad in front of the passenger side head.....
HA 1965 327 4 spd tran. std 275 4 full size/Camaro HA 1969 350 manual trans 300 4 A F X It shows it could be a 327 or a 350 The casting number 3903352 shows. 1967 3903352 327 210 350 2 cars only So, it looks like a 327/275 hp....... A little pricey for a rebuilder in my mind. |
#3
IMO, not worth any more than maybe 3-4 hundred if you just had to have a 327, unless it was fresh and was loaded w/good forged innards.
Better bang/$ buy a Vortec 5.7L long block unless you're building a period correct deal or restoration back to original. |
| Thread Tools | Search this Thread |
| Similar Threads for: "327 engine codes" | ||||
| engine vin codes | badmystur | Engine | 2 | 09-24-2010 08:31 PM |
| engine codes | 66chevynova | Engine | 5 | 08-31-2009 09:00 PM |
| Engine Codes | yourmoma64 | Engine | 1 | 08-22-2007 08:09 PM |
| What exactly is my chevy engine? Have casting and engine codes | optV | Engine | 4 | 05-04-2006 09:40 AM |
| Engine Codes | dragrace87 | Engine | 3 | 12-01-2003 11:54 PM |
